Generally speaking, a proof-pressurization test after major pressure vessel mods/repairs, and/or during every depot maintenance cycle, is an excellent requirement.
Reasons are varied.
Verifies static load capacity of the mod/repair and of the entire pressurized structure; and confirms there is no noticible deformation or yield... especially around mods involving the skin. Any weaknesses are likely to show-up at this point. Be prepared to inspect around the mods/repairs using straight edge and fuselage contour gages to help find bulges or distortion.
Proof [overload] pressure also tends to stress [strain] relieve minor defects. When I worked on T-38s, there was an expectation of an occasional over-load [+over-G, every 500--1000-Hr, student pilot induced]. The nature of the structure was such that this was considered stress/strain relieving [cold-working] for small cracks... especially useful for extending life of the wing skins and body longerons.
Proof-pressure loading also ensures proper sealing has been accomplished and the structure is "tight" within leak-rate limits.
There are a couple of other benefits, such as...
Ensures that doors and panels seal properly and continue to operate [open-close] normally.
CAUTION. make SURE doors and large panels have protective strapping/webbing loosely covering over them... just in-case one comes loose [will make a bad day for everyone]. For certain mods/repairs this might be a good idea also.
Also... these tests tend to uncover the odd [1-off] system of structures "surprises" that may be hidden, such as loose or leaking [bleed or ECS] air ducts; pressurization-induced binding of controls, etc..
OH yeaaaa if You hear a loud BANG expect the unexpected.
A few years ago a crew at Tinker AFB was proof-pressure testing a KC-135R using engine bleed air and with the out-flow valves blocked [on the ramp]. Equipment problems and operator errors [buffoonery] lead to a gross over pressurization event [~8PSI above proof], which resulted in catastropic failure of the aft upper-deck pressure bulkhead. Photos are on the web IF You're interested.
Regards, Wil Taylor
Trust - But Verify!
We believe to be true what we prefer to be true.
For those who believe, no proof is required; for those who cannot believe, no proof is possible.
