pressure drop test nitrogen instead of helium
ozanooz
Aerospace
Mar 26, 2025
5
Hi I wonder something, I have an valve working with helium gas but ı can not test with helium right now. When ı change the fluid by nitrogen. How can I verify actual the pressure drop if I do my tests by helium gas.
Explain to us WHAT you are proof-pressure testing with Helium... and what kind of pressure-loss sensor you are using...
Your question is a bit 'off'... perhaps You mean: "if you are supposed to pressure test with helium... and all of the pressure test 'plumbing/valves' are designed for Helium... then is it OK to pressure test with nitrogen... or NOT"?
Are you testing for pressure drop over time or pressure drop from flow? Pressure drop over time indicates leakage which helium is commonly used to test for. Is this your case? If so, nitrogen is not a substitute.
Please clarify what the working gas is supposed to be, nitrogen or helium?
If helium, then nitrogen as a test gas is completely inappropriate, since N2 is a substantially bigger molecule than helium. Moreover, helium is an industry standard leak testing gas, and there are instruments designed specifically for detecting helium leaks.
Tug, IR... You have hit the nail, squarely on the head!
[B]ozanooz[/B]'s question lacks enough facts and candor for us to address.
Sounded to me like the OP wants to measure a flowing pressure drop (total pressure loss) across an open or partially open valve, i.e. a Cv curve. But, as Wil said, you need to be more specific about what testing you are contemplating.
It is still tricky to measure with nitrogen and then translate the flow data to helium, given the big difference in JT coefficient. But for low expansion, low delta-P you might have some success, just comparing volumetric flow rates.
Pressure drop testing as a leakage test is more problematic, as others have noted.
Perhaps use a hydrogen-helium mix to conserve helium... without blowing-stuff-up?
Sorry... I'm over-thinking this...
Maybe I asked wrong question. All my line valves also designed for helium gas. Nominal working conditions of line such as 5 bar, 10g/s helium but I don't have helium supply, I have nitrogen, then I will test my valve by nitrogen gas on same volumetric flow and calculate capacity. Is it good method to verify capacity of valve.
Changing flow type and try to find and point of similarty.
Thanks for your reply, as you said test is about measuring flowing pressure drop. yes changing flow media is problematic but is there any way to making similarity beetween two point with helium and nitrogen, such as on same volumetric flow make test with nitrogen then verify datas with cfd analyse, later CFD analyse by changing flow media.
Test is not about leakage its about flow performance.
I re-read Your statements... and several subtle elements finally made me curious/concerned... with Your presentation... Soooo I have to ask...
Are You testing with gaseous/pressurized... OR LIQUID... helium?
Gaseous testing under pressure at most useful temperatures 'is straight-forward'.
HOWEVER, testing with liquid helium at -269 °C (−452.20 °F; 4.15 K)... which is a radically different environment.
Please advise.
Please advise.
We can think all media is gas at room temperatures
There are 2 big differences between He and N2
He has atomic mass of 4 and N2 has an atomic mass of 28
This is a 7 factor ratio in the mass per molecule/atom this difference in mass will affect the throttling characteristics
The other is He is monoatomic, it is just one atom per molecule and can squeeze through places that N2 cannot which has 2 atoms per molecule
The other thing to keep in mind is the different k factor due to the mono/diatomic which changes the temperature/enthalpy characteristics
Hydrae
gamma (ratio of specific heats) of helium and nitrogen will be different. So unless you are doing an isothermal experiment then you'll need a more complex correction to get the performance with helium.
oz... WHY are you unable to obtain sufficient [any?] Helium for testing? It is not cheap... but it is available...
Also... FYI... for what it's worth... stumble-over... NASA-STD-7012A LEAK TEST REQUIREMENTS
Various gases and fluids mentioned.. and there is appears to be [possible] conversion factors between several gases/fluids and/to helium... but not sure exactly what that means...
