Mustafinho
I am a recent grad and I just landed a job with a company that doesn't have an engineering department. I am required to do some preliminary engineering analysis for some custom/extruded shapes of steel and/or aluminum. Simply put, I want to determine the unsupported span for the shapes.
I have been toying with RISA 3D and Virtual Analysis but it appears that code checks won't show up in the results. I have used ShapeBuilder to get the shape properties but when I import that in analysis it won't work.
Is there a way to perform preliminary analysis using a standard shape that is similar to the custom shape's properties? Any hints or tricks would be greatly appreciated.
Thank you in advance for your responses.
