KootK
- Oct 16, 2001
- 18,601
I am curious about the capacity of strip foundations at corner locations. If I have a column point load on a straight section of foundation, then I realize that I can consider that load as distributing out to either side.
Is that the case with a point load applied to the corner of a strip foundation however. I would expect that whole assembly would behave as an eccentrically loaded structure. I would think that the corner would tend to sink and and the foundation segments extending from the corner would be much less effective in resisting the vertical load than they would be for the straight wall situation.
I am currently looking at a location in a structure where there is a 2' jog in the foundation wall. If the point load is applied to the far corner of the jog, how much of the surrounding foundation can I consider as helping to resist the load? Maybe it could be treated like an eccentrically loaded mat foundation with some material missing?
Does anyone have any recommendations or references for this kind of situation? It occurs on virtually every builing so I figure that it must be addressed somewhere.
