Stress Relief of smallish 316 parts 1
123Dog
Industrial
AU
Yes they are about 100mm or smaller
Wire cut , machining , that sort of thing
My question
To what temp do I take the rough blank , and for how long
And also how do I cool it
My guess is 1100C, and rapid cool same as for annealing , I may be wrong
I have performed stress on small 316 SS parts at 850°C holding for 5 minutes and air cooling. This will give you all the relief that you need in short of quench anneal at 1100°C. The parts need to be cleaned, grease, oil, fingerprints, etc.
They only disadvantage is they have a heat tint when removed. If the heat tint is acceptable it is an excellent passivation procedure.
Yes Uncle
I had a feeling a lower temp would suffice
Thanks heaps
850C is risky. There are a number of secondary phases that may form/not disolve at that temp. If your starting material has a nice clean microstructure and low C, you can probably get away with it.
1050C is a better bet.
If the parts are thin then cooling should be an issue. They will cool plenty fast
Corrosion never sleeps, but it can be managed.
Thanks EdStainless
Much appreciated for your brain work
I will count on you when I get an important one
