I am trying to plot stress concentration factor for a rectangular beam (6x1.5x.25) with a hole .25 dia in the center of the largest surface. I constrained the beam at one end and applied a 100lb load at the other. I want to know which is a good location to look for nominal stress. I want to iterate this for different hole sizes on the same plate. If I pick the location for nominal stress away from the hole like say near the constraint or near the load then the stress is not changing much at that location with a change in the hole dia as a result my Kt is increasing with bigger hole instead of decreasing. Thanks in advance.
Joe
Joe
