freefallingbody
Hi all,
I am trying to estimate operating efficiency of a 50 Hz, 11kV/433V, 1000 kVA distribution transformer. I have measured no load losses, which I understand is essentially the core losses. Now, from the measured winding resistances on primary and secondary sides and the load current measured, I can estimate the copper losses also.
Problem is, can I assume a stray loss value?. In motors, I know I can take values from IEC recommended values as per IEC 34-2. My question is whether there is any such values for transformers?
(If I conduct a short circuit test, I can measure the total load losses, inclusive of copper losses and stray losses. But I don't think it is possible.)
Can you guide me?
Dinesh
Can you guide me?
Dinesh
