Strange Symbols Printing on Every Sheet 1
random_guy
72
Hi All,
While this is my first post on this site, I have used it many times to find help with Pro-E. Thank you all for that.
I am currently having trouble figuring out the source of a strange symbol that is appearing on all the sheets within one of my drawings, but only when I print or create a PDF of the drawing (they are not visible when moving among sheets within the program.
I believe it is related to a surface finish I have placed on one of my sheets, but it is not visible on any other sheet in the document, even when I print screen.
What is interesting is that if I print a sheet individually, the symbols will not appear, but if I print the entire drawing they show up on every page. Strange huh? Yesterday I was able to print each sheet individually and then I could PDF the drawing and the symbols would not appear.
I'm hoping someone else has previously had this problem and found a solution to it.
Thanks in advance!
Got it figured out!
I deleted all the surface finish controls from the drawing and I no longer have the problem... yet another weird glitch cursed upon me by the Pro-E Gods...
Hope this helps if anyone stumbles upon the forums here.
Frequently problems like that can be fixed by exiting Pro/E and restarting. Less drastic than deleting a lot of symbols & redoing the work.
That's usually my first solution. I tried exiting Pro-E and restarting the PC, neither worked.
Deleting symbols was a last ditch measure!
Thanks for the help!
