I know if you have an mainline urban pipe system, running/flowing a certain directioning down a highway, SW pipes connecting in from sites should be bearing the same direction, being perpendicular at worst. Is there much tolerance for the tie-in pipes being off-perpendicular in the other direction?
Example: If you have a mainline longitudinal pipe running/flowing east, can you tie in an outfall pipe from a SW pond to the system bearring slightly west, like maybe 10 degrees from being perpendicular?
