Storm shelter addition 1
TroyD
98
An architect sent me this sketch of a proposed addition to an existing storm shelter. To support the pre-stressed plank roof above, I am proposing a 12" CMU bearing wall be added parallel to the existing exterior wall. (I don't want to add any axial or lateral load to the existing wall). I show a new footing "scabbed" on to the existing footing. I am familiar with the ICC 500 design requirements (250 mph wind speed). Are there any other recommendations for constructing two CMU walls next to each other? What is the appropriate method/spacing of tying together? Any advice is appreciated.
 https://files.engineering.com/getfile.aspx?folder=a2b2245d-7569-4189-a04e-c240f8103626&file=CCF_000455.pdf
I think you shall pay attention to the interface of the walls. Either grout it solid, or leave adequate air space to avoid condensation and relate problems.
Consider differential settlement between the 2 walls. I think a gasket type system might work.
