LittleInch
Petroleum
- Mar 27, 2013
- 22,602
I am currently looking at options for large storage tanks (> 100000 bbls) for hot crude oil. Currently the true vapour pressure is approx 13.5 psia at the storage temperature. The tank designers are of the opinion that above 11 psia, this excludes standard atmospheric or cone roof tanks or floating roof tanks. I have some sympathy with this as in order to maintain temperature at around 65 C, this will require heating which could generate significant amounts of vapour as the heating element of whatever sort (hot oil, water, steam) will probably need to be higher than the bubble point at atmospheric conditions.
So the question is - is the 11 psia vapour limit for standard API 650 tanks valid or can it be raised?
Are there other options? We are looking to raise the bubble point upstream, but need to show that without it the tanks will cost a lot more.
Any insights, experience, links to papers or data would be gratefully accepted.
My motto: Learn something new every day
Also: There's usually a good reason why everyone does it that way
