stop osnap from snapping to a hatch 1
paulvrug
NL
When I want to draw a line or something and osnap is turned
on it also snaps to lines that are in a hatch.
(endpoint, midpoint, intersection)
Can anyone tell me how i can stop autocad from snapping to hatch lines in a way that it stil snaps to lines, circles etc.?(I mean not by turning osnap off)
Thanks,
Paul.
Not sure but put the hatching on a different layer and turn it off will work. I am sure someone will give you a real fix.
Paul
Overriding running object snap modes can be turned off by right click the OSNAP button at the bottom of the screen. This will bring up Drafting Setting dialog box and you can remove the active checks as needed to disable running object snaps. You can also pick to disable all running modes or pick the select all to activate all object snaps. Hope this helps - John
2005 has the option to turn off snapping to hatch objects. It's in options...user preferences.. I think
