Stilling pipe inside of a vessel
orlandini
7
I need to install a stilling pipe (stand pipe) inside of the vessel. It will be welded in the botton and in the top inside of the shell.
For a safe design, what kind of calculation I need to do?
An Expansion bellow will be required in the stilling pipe?
The internal pressure will be 25bar.
Do NOT use an Expansion Joint on the stilling well.
Just use a simple (three point) guide at the bottom of the stilling well pipe so it can expand down but not impede the flow
Dear pennpiper,
I usually use a three point guide for stilling well pipe, but, for this case, my client specified a nozzle in the top and other in the botton of the vessel. The stilling pipe will be between these nozzles and it will be welded. I can´t use a guide for this case.
I do not understand what this will look like. Can you share a sketch of this double nozzle stilling well?
Is the pipe a stand pipe or a stilling well? A stilling well is a pipe with many holes, to protect instrument inside the pipe against liquid movement, but allow liquid level inside the pipe to be same as the vessel liquid level. A stand pipe does not have holes.
Dear austsa,
It is like a stand pipe but my client calls it stilling well.
This stilling well does not have holes.
orlandini,
See definition of stilling well at By definition, stilling well does not contain pressure, and thus to answer your question, there is no requirement for calculations for a (true) stilling well.
Regarding your client requirement however, it seems like its piping that is inside a vessel. On top of my head, I can only think of one reason for this ... heat transfer ... but it seems a very odd way to do it. If the internal flange was to leak in the future, how would you find out?
If there is reasonable temperature and/or material difference between vessel and piping, then you'll need to cater for thermal expansion.
austsa
