Brad,
Thanks for the reply. I shall refer to the Abaqus manuals.
The confusion is because I know that for constant k, the PDE is k.div^2(T)=0 for steady state but for k dependent on T then the equation should be div(k.div(T))=0 which I thought would be treated differently to the text book references I have, as the PDE now involves the differential of k. For stress analysis elastic material properties are simply calculated at the known temperature, but for heat flow it's different, unless it's done iteratively, I think.
