AlpineEngineer
Thanks so much for all your input on my last question about the overturning moment on a shear wall; it all makes sense now, I wasn't fully understanding how the roof diaphram forces transfer to the shear walls. FYI I found a great online resource for us slow learners:
Now, my question is: If I have a stick built roof system with a ridge beam does this diaphram behave like a webbed truss diaphram? It would seem to me there should be lateral loading consideration on the ridge beam and its connections, but then it is starting to look like a post/beam frame that takes lateral loads (a moment frame, right?). Is there a way to build this ridge connection so that there is no lateral load transferred to the ridge beam (maybe blocking between the joists at the ridge beam and nailing into the blocking?) I've looked in Breyer's book and I don't see any considerations for stick built roof diaphrams and this ridge beam consideration.
Thanks a ton guys.
Thanks a ton guys.
