I have engine simulation software, but its really questionable. Its the performance engine analyzer by performance trends. It sometimes acts very oddly, and often states the pumping loss as negative (as in negative negative or positive) So I'm very skeptical to its use.
It got me thinking as to what the mathematical approach to doing something that complicated was. In my mind I know exactly what it looks like, but I have no idea how to solve it even holding rpm fixed.
It seems as if larry's method is to make the total length fo the step header approxiametely the same length as the tuned primary, but add steps so that there are reversion waves every so often which accent other rpm ranges. I have no idea how it arrives at the crossectional steps. Perhaps they are setup just to be sure there is a reflected wave? Then at some point velocity gets very low, so great changes in crossection are needed to create a meaningful pressure wave at the valve. At the same time I would imagine the overall effect of the header is less.
Really I'm just looking for some good literature on it. I have a car to apply it to, its a small displacement 4 cylinder, but I'm more interested in a general approach to any vehicle.
