stinsondawg
I'm using Dave S. Steinberg's "Vibration Analysis for Electronic Equipment" to calculate the allowable displacement for a PCB (printed circuit board) with surface mount components. One of the equation variables is the thickness of the PCB. If my PCB is mounted to an aluminum housing should the PCB thickness include the thickness of the aluminum housing? Also, I'm not sure why the equation needs to know the PCB thickness? It seems to me that the surface mount components don't know how thick the PCB is.
