walrus102882
I'm just curious how others repair a cracked hollow section? I have a hollow section that was not capped and water was able to enter and freeze. This resulted in a vertical crack just above the base plate. Due to the expansion of the steel the concrete was also damaged. In a case like this, I'm just curios if others prefer to replace the entire section or cut away the damaged area and weld a new section in its place? I included a pic to give you a better idea.
