There is a new steel tube installed over the existing building structure to support ACM panel cladding. I’m reviewing whether the calculated wind pressure of 31.8 psf is acceptable for this connection.
Do I need to perform my own wind pressure calculation to verify this value, or should I be reviewing additional information such as anchor details to determine if the steel tube is adequate for the load?
Please see the attached PDF for reference.
Thank you in advance
