Imperfections of a harmless nature, for example pitting, rolled-in scale, indentations, roll marks, scratches and grooves, regarded as being inherent of the manufacturing process, are permissible irrespective of their number, provided the maximum permissible limits of Class A of EN 10163-2, are not exceeded and the remaining plate or wide flat thickness remains within the average allowable minus thickness tolerance.
Total affected area with imperfection not exceeding the specified limits are not to exceed 15% of the total surface in question.
Affected areas with imperfections with a depth exceeding the limits of Class A of EN 10163-2, shall be repaired irrespective of their number.
Cracks, injurious surface flaws, shells (over lapping material with non-metallic inclusion), sand patches, laminations and sharp edged seams (elongated defects) visually evident on surface and/or edge of plate are considered defects, which would impair the end use of the product and which require rejection or repair, irrespective of their size and number.
