Can somebody shed some light at the structural analysis reasoning behind the system where you have CMu Bearing Shear Walls enclosing a steel frame where you have only shear connections (No Moment resistant type whatsoever). Most of the bays of the frame or all, are infilled with cmu and the brick veneer is on the outside plane.
What considerations should be taken for potential cracking due to significant wind load displacement. The typical building would be 5 to 7 stories high and seismic does not control de design.
Regards, any thoughts would be appreciated.
Rare Bug
Rare Bug
