steel connection 6
wrxsti
196
In AISC Design Example K.1 - Welded bolted wide tee to hss column
Wide Tee welded to column and bolted into a W section.
For bolt capacity they use eccentricity
The configuration resembles a conventional configuration for single shear plates
however for conventional configuration on single shear plates eccentricity can be ignored.
If the single shear plate connected to column/girder is ' conventional '
but instead of the connecting member being web of a wide flange, tee or whatever
its now a tongue extended from a cap plate of a hss
can i still use the conventional design checks for weld and bolt of the single single plate?
and what about tongue to cap plate weld?
cap plate to HSS?
Also noted is the change of Von Mises Shear reduction for interaction checks from AISC 13th to 15th (not sure about 14)
to (Vr/Vc)² + (Mr/Mc)² <= 1
