Curious Detailer
I work for a steel fabricator and we use Tekla to generate our Erection drawings and Shop details.
1) What is the best software out there that can design X-Bracing, Moment connections, Beam to Beam, Beam to Column type connections? Our detailers usually cover 90% of our standard beam to beam and beam to column connections by following established standards but we always need our connection engineer to design the more complex connections like X-Bracing and Moment connections.
2) We also would like it to be Tekla friendly and we can import the model into the design software. This way the connection engineer does not have to spend time regenerating a model. Also, I know you can import a IFC from Tekla but once the connections are designed by the software you input the model into, you can't take that model and import back into tekla with the new connections (as far as I know)? Anybody know more about this?
3) From my experience, our connection engineers use Safi and Ram. The printed reports for each connection are not the greatest. Most times I see our engineers manually writing out additional notes on each connection. We are looking for a more efficient system where the info generated and printed can be quickly be given to the detailers so they can update their tekla model.
Rookie user on the site. Wondering if anybody has a better system than the one we seem to be stuck with
