We are designing and office building with precast concrete floor on concrete beams. I have 2 questions.
1. In designing the steel beams, how are most people attaching the concrete to the beams? Either with embed plates or shear studs and grout? (We will be using a 2" topping for leveling purposes). This appears to be the only way to say the flange is braced.
2. Is the steel beam braced during construction? It appears that with either of the methods above, the steel beam would need to be braced by the erector, or the beam would need to be designed for dead load, and construction live load for an unbraced length equal to the span. How is this normally done, or what do i need to specify?
