I am currently doing a review of steam flow metering systems. I know a reasonable amount about flowmeters but I'm a relative novice on the subject of steam systems. I believe that one of the primary sources of flowmetering error is that steam quality is rarely known. This is obviously not an issue in superheated steam but it is in saturated steam. What I would like to know is what are typical operating conditions for steam systems. Based on various conversations I've had I am coming to the following tentative conclusions -
1. Relatively large scale systems (e.g. in refineries or chemical plants) usually transport superheated steam (and then desuperheat at the point of use)
2. Nuclear and geothermal systems can be very wet (less than 90% quality).
3. In smaller scale systems (e.g. building heating, hospitals etc) the quality depends very much on how old and how well maintained the system is. A well maintained new system will probably operate in the 90 to 97% quality range). An old system may be much worse than this.
Does anyone have any comments on the above or further information.
Thanks for your help.
Neil
Neil
