Thanks for your response. I had already reviewed the link you mentioned, but it didn't provide the information I was looking for. The recommended slope in a counter flow situation is 1:40, but it also notes that the pipe diameter should increase in the uphill section by some amount.
This naturally leads to the question I posed, which was whether or not there is any information available on the required pipe slope by steam velocity.
Clearly, with a higher steam velocity, more slope is needed to drain condensate against the steam flow, which explains why the pipe diameter may need to increase in uphill sections. I am interested in any information relating slope to steam velocity. Surely research has been done?
