Saver2008
- Oct 14, 2008
- 112
Hi everybody!!!
I have a carbon steel pipe that will be used to transport SUPERHEATED STEAM. This will be used just for some situations (for a flare stack that when it flares it makes smoke and the intention of this steam is to get better the combustion and eliminate the smoke. So...this pipe line for steam will be used for this circunstances, not all the time. Some persons have told me that when you have a pipe line with no fluid and suddenly you put SUPERHEATED STEAM (a fluid very very hot and I mean hot as 300 celcius)the pipe line will "colapse" or it can be cracked or something like this. I do not what is the correct name for this phenomenon...can you tell me what is the correct name? Thermal cracking or something like this? And also, in order to prevent this, it is necessary to keep the carbon steel pipe line with a minimum quantity of steam in order to keep it HOT...is that really true?
Please help me with it.
Thank you very much
R
Thank you very much
R
