Steam flow calculation 3
flinana
SA
I have a calculation based on enthalpy so as to attemperate steam to a turbine. The calculation has the following formula which I can´t understand.
Flow = m x(Enthalpy (HPT)- Enthalpy (CRH) /Enthalpy (CRH) - 764.8) kg/s
Enthalpy (HPT) = High pressure turbine. Enthalpy calculated from presssure and temperature before HP turbine
Enthalpy (CRH) = Enthalpy calculated from pressure and temperature before reheater, to where the HP steam is bypassed.
m = mass flow according to Steam valve opening, using pressure and temperature before valve.
Find logic attached.
The part I dont get is (Enthalpy (HPT)- Enthalpy (CRH) /Enthalpy (CRH) - 764.8).
Can someone explain.
thanks
Finana,
You have stream IN with enthalpy equal to enthalpy (HPT).
You have stream OUT with enthalpy equal to enthalpy (CRH)
The value 764.8, I presume expressed in kJ/kg, should be the specific water enthalpy at saturation pressure (9.08 barg) or saturation temperature (180.344 °C) before reheater. What works here is the enthalpy of evaporation, which is the difference between the specific enthalpy of steam and the specific enthalpy of water.
thanks, but i dont get is why the enthalpy out does not include the enthalpy from the ST outlet. Enthalpy in = enthalpy out, i.e.Enthalpy of steam = enthalpy of steam after water has been sprayed. But the pressure reading is taken after the connection from the ST hP exhaust!! see my dwg attached.
 http://files.engineering.com/getfile.aspx?folder=869b8baf-a248-4ba5-8afb-630c5e02f117&file=20101001110907.pdf
sounds like they've taken the worst case (no work by the turbine)
Good point hacksaw. But why attemperate in that case?
Just rearrange the terms and end up with the first law balance across the spray station:
(Whpt+Ws)*Hcrh = Whpt*Hhpt+Ws*Hs
where Hs= spray water enthalpy
