Dear Members:
I am conducting an analysis of a cogen cycle and found something I'd like you to comment on.
The turbines I analyzed are single stage turbines. I contacted the companies that made them and they gave me their steam consumption rate as a tool to obtain the efficiency of the equipment. The value was given based on the plate's operational conditions. Now, I have better steam properties than those indicated in the equipment so the steam consumption I got theoretically is quite lower than the one they gave me.
I followed the procedure they told me to follow in order to obtain the efficiency but the value I think is not reasonable (quite high for a single stage turbine). The procedure they told me is the following:
I have to calculate the steam consumption with the plate's operational conditions considering a 100% efficiency and then obtain the steam consumption with the steam rate they gave me, then I have to divide the second value into the first. They say that should give me the efficiency.
Now, for the operational conditions I have, it gave me a lower consumption per kW. How can I relate this even lower value with those I obtained in order to get an efficiency value?? Getting it like that obviously throws an efficiency of more than 100% !! This guys really confused me here... anyone out there willing to give me some tips or a procedure to do this?
Best Regards
MAEC
Manuel
Best Regards
MAEC
Manuel
