MinnesotaSlinger
- Feb 13, 2008
- 23
We are installing a 125 psig steam main through the basement of a building. The amount of ceiling space is quite limited and the run through the building is several hundred feet, so we'll have to trap at every steam main low point where it rises up before sloping to the next low point. My question though is about the corresponding condensate return line that will serve the traps on the steam line. It's typically suggested to slope a condensate line back to the flash tank (and, in our case, we have a 15 psig system we intend to serve with recovery steam), but there isn't ceiling space to continuously slope the condensate return the whole way back to the flash tank. So long as the steam line is under pressure, there will be motive force to push condensate/flash steam through the condensate line back to the flash tank without relying on gravity, but if there are any low points in the line, I'd worry about water hammer if a burst of 2-phase flow collides with condensate pooled at a low point. Is there good guidance somewhere in how to pipe a condensate return line when you can't continuously slope it down the whole way? Thanks.
