I'm doing some analysis for a project and am looking for some guidance related to steady state heat transfer.
Steady state heat transfer, as the name implies, is independent of time. Using Equation 16..20 as an example; the temperature distribution for slab via steady-state, one-dimensional conduction is only dependent on heat flux, thermal conductivity, and slab thickness. But logically, shouldn't the temperature profile for the slab become uniform (dT/dx = 0) as time approaches infinity? The energy should equalize and both sides of the slab should eventually be the same temperature. How long is this steady state heat transfer equation valid for? I feel like I'm missing something very obvious, the math does not match my intuition.
For some more information, I'm looking to design a composite wall layup for my project. Given a set heat flux and ambient temperature, I am choosing my wall properties such that the inside of my wall stays at a reasonable temperature. I'd like to know how long the inside of my wall can stay at this reasonable temperature.
