djw2k3
- Jan 20, 2003
- 190
Basically I have a fixed shaft (no rotation) through two blocks spaced about 100mm apart with the the shaft effectively cantilevered out 100mm from one face of the blocks (total shaft length ~200mm). The load is applied in one direction on this cantilevered section. If I do the calcs on bearing stress in the block (nearest the load)the stress is okay. Wanting to be thorough I modelled it using FEA, the latter approach showed that the stress is significantly greater where the shaft intersects the block - which stands to reason as it is really a concentrated load here.
Basically I am after an analytical estimation for this stress which gives a more accurate answer than just using a bearing stress calc. Or is it just a matter of adding an appropriate stress concentration factor??
thanks
Dave
