MDCOX
Computer
- May 12, 2010
- 3
Hello everyone.
Lately I have been doing alot of research on computer fans. I have been testing CFM and in the process the comment "static pressure is more important" keeps coming up.
Here is my two part question:
If the idea of a computer fan is to move HOT air OUT of the case and to move COLD air INto the case, wouldn't CFM be more important?
And it seems static pressure is measured mostly in air ducts or (from research) animal holding facilities. So I can agree that the computer case itself is a duct of sorts but the primary goal is to move hot air away and from the components and get cool air to them. So is static pressure more important in this situation?
Just FYI:
Most people setup the fans so they have 1-2 in the front of the case as intakes pulling fresh air in, 1 intake on the bottom of the case, 1-2 exhaust setup on the back panel and 1-2 exhaust on the top of the case.
So fresh air flows in from the front and bottom while hot air exits the back and top.
I hope I articulated all that sufficiently. If not bare with me and I'll get it right.
Thanks in advance for any help.
Just FYI:
