NDS gives the example of 30d nails for a 3 ply 2x6 built up column. Is there an acceptable alternative without using 30d nails? One provision (in NDS) is that all fasteners penetrate all plys 75%. I'd like to use 3" or 3 1/2" inch nails as they are more readily available and want to avoid bolting. (A 2x6 column would require substantial bolting.)
Is there a good reference for this or otherwise a "standard" using nails?
What about if 4 ply columns are used? Is bolting the only acceptable way?
Any specific reference books that illustrate (perhaps with a table) the allowable options for built up columns?
