StevePAA
- Mar 21, 2008
- 28
a few yrs back (!) I started this thread on trying to find a K value for SS screws into aluminum.
The above thread is closed so I figure I'd start another.
I tried to get the company to do a load cell study to measure clamping force vs torque to calculate a K, but that didn't happen. So, I ended up taking a less scientific approach myself and broke off a bunch of SS SHCS into a piece of 6061-T6 (using a SS flat washer under the screw head) and recording the torque where they failed. I also broke off SS screws into SS hex nuts to compare. What I found was that the failure torques were usually within 10% of each other- the alum didn't make a big difference. This makes sense to me because the friction between the washer and screw head should be the largest friction source.
In addition I did minimum thread engagement verifications and found 6061-T6 to be good stuff (no surprise) and that you do not need a lot of engagement with an 18-8 SS screw to have the screw fail before the threads strip in the alum- generally ~1.2X screw diameter is about the minimum you would want. I first calculated min engagements based on shear strength of the alum thread area vs fastener tensile strength and then verified and the calcs were accurate: yes, math works.
For my "test" I used a SS flat washer under the screw heads, 18-8 SS SHCS and tightened until tensile failure. From failure torque, SHCS size, and matl strength I back-calculated a K value. I realize this isn't the right way to do this but I wanted to get some data. What I found was that K was approximately .35 for #10 thru 1/4 sizes. This is slightly less than the ~.40 values if you back calculate from the NASA and ITT tables on SS fasteners.
For comparison I did a few tests into the alum bar with a grade 2 zinc plated 1/4-20 HHCS and FW and found K at failure was .23; it failed at a significantly lower torque than the SS 1/4-20 screws.
So, stainless on stainless= lots of friction as already known.
Again, these K values are from failure torque and this might be giving lower K values than actual because the screws are well into yield at this point. Opinions on this?
I think the summary is that if you are using clean, dry SS screws (no lubricant), with a SS flat washer, then you can basically use the NASA table for torque and will be ok
