ST2 the verdict - So far 1
karmoh
Industrial
AU
Hi All,
I'm just about to switch to ST2 (from V20) and was wondering if any of you are using (ST2 that is) and your thoughts so far
Cheers
I tried inserting letters in the balloon without success so I don't think it's possible.
Patrick
Thanks Pat,
If we can get our partner to go to ST2 at least we have a 'user defined' column that we could use for item ref.
Not ideal.
The problem arises because our cient is using a system from 30 years ago and manual drawing when you detailed some parts on the assembly. A part detailed on the sheet has a number for the ref, but a part called up from another drawing has a letter ref.
bc.
2.4GHz Core2 Quad, 4GB RAM,
Quadro FX4600.
Where would we be without sat-nav?
