I'm puzzled that nobody has asked what is causing these loads. It is a very odd loading and I'm curious. Part of my curiosity stems from the fact that to solve this problem, it would be nice to know if there is a stiffness associated with any of these loads, to wit:
- does the load stay the same as the deflection increases? (gravity-type loading)
- does the load reduce as the deflection increases? (spring-type loading)
Knowing this, I can also attempt to evaluate how much the side loads act as a brace point for my overall column buckling.
One other thing that I find lacking from the replies is the question of how much of the wall will contribute to resisting those lateral loads? inertia4u's spreadsheet is nice, but it doesn't mention this at all.
If this problem was on the borderline, a good FEA model may have been in order.
For the problem at hand, however, I think your walls are in trouble. If you assume that 16 times the thickness of your plate wall contributes to resisting the side loads, we get an 8" width. Using this and the 1/2" thickness, the moment of inertia for the section is 0.0833in^4 and the applied moment is about 31,900inlb which gives a max stress of over 95ksi. This does not consider the axial load from the two opposing walls, nor the axial stresses from the 137kN in the other direction. Unless this is a pretty exotic material, it's just not happening...
A possible solution: beef up the central section to resist the center wall stresses by either making the local portion much thicker, or installing a central plate for these loads to pass through. Once that problem is solved, if this is steel, there are no buckling issues (local or overall) with the assembly by my estimation. The axial stresses (from the 137kN load) are a good deal less than 2ksi and this is a pretty stocky column as has been mentioned.
If you "heard" it on the internet, it's guilty until proven innocent. - DCS
