4130 metalworks
Hi, I am looking for any papers or research done on hydraulics external gear pump heads with spur gears. We are trying to optimise our existing pump by altering tooth counts and clearances. Before spending lots of time and money on prototypes I thought there could be studies already done in this area. Also if anyone has information on coating the internal walls of piston type hydraulic accumulators to help with the stick slip effect.
Thank you
Thank you
