PUMPMANPLEE
Greetings Gear & Pulley gurus,
i wish to drive a screen equipment
at 1.3 r.p.m constant speed.
i have a gear reducer operating
with a VFD (variable frequency drive)
capable of 0.5 to 5 r.p.m.
the output shaft on the gear reducer
will be set at 1.3 r.p.m using the
VFD.
there will be a chain sprocket on
the gear reducer output shaft & a
chain sprocket on the screen equipment
shaft.
what is the number of teeth to be
selected for the drive output shaft
& the screen equipment shaft ?
the drive output shaft diameter
is 50mm & for the screen equipment
shaft it is 50mm.
pumpmanplee
VFD.
shaft.
shaft it is 50mm.
pumpmanplee
