Spring element between solids
aleximos
DE
Hello guys!
I'm trying to model some solids elements connected with ONE spring CBUSH element and I have rigid motion problems :(
Do you have any idea, how to eliminate this problem without modelling couple of spring elements?
P.S. I've constrained the rotational dof of the CBUSH, but I'm still getting rigid motion.
 http://files.engineering.com/getfile.aspx?folder=f0176ee2-d79c-4164-97ce-22ec6337135c&file=spring_between_solids.dat
3D element nodes do not have rotational stiffness.
what you could do is use RBEs to connect the CBUSH nodes to several nodes of the solids (so that the moment in the CBUSH is distributed to several nodes, as couples).
Thanks rb1957! I played a little bit with the RBEs. From the one side I created RBE2, so it will deform as a rigid body and to the other side RBE3, so the load would be uniformly distributed.
