SiW979
- Nov 16, 2007
- 804
Hello everyone.
I'm messsing around with splines at the moment doing something which should be relatively simple, however the outcome is a little problematic. Have a look at the attached model, there are 3 splines 2 of which are over built and spline 6 is attached to the other 2 with G2 continuity using the point on curve snap associativity in an attempt to give me a smoothe path I can use to make a trimming sheet. However, as you can see by the extrude feature, there are breaks in the surface. I have tried using law extensions, reducing the modelling tolerance, using the stop at intersection and follow fillet options, but I'm not able to create a perfectly smooth sheet. I was told that over building splines (and sheets) was good practice or am I missing a key piece of info? Perhaps someone could explain where I am going wrong please?
Many thanks
Si
Best regards
Simon NX7.5.4.4 MP8 - TC 8
Many thanks
Si
Best regards
