Spiral mixer 240v is 2 Speed
Kuldipkenya123
Industrial
Nov 19, 2022
1
I had a Single Phase motor for Rewind. It is a normal single speed winding. Start and run cap with a centrifugal switch. BUT there are 2 switches on the panel. One for high speed and other for low speed. I am having difficulty in wiring the motor onto the contractors. It has 2 Contractors. The machine has a Emergency cutout switch and a timer. Can anyone Help me with the wiring..
One cannot know the external wiring if the internal connection is unknown.
There are many different versions.
So, post the winding diagram of internal connections, nameplate photo etc. Maybe it will help.
Winding Design and Motor Repair
Did you look on the motor nameplate or under the connection box cover for a wiring diagram?
