Simulation? Why?
I have been doing electrical engineering for over 30 years. I started this stuff when I about 6. In 7th grade I built an exploding wire system for launching balls. In eighth grade I built a Tesla coil that took two people to carry and stood 6 feet high. I can understand simulation or modelling if you are trying to design an integrated circuit, which you really cannot ever build, but rather you cook up in a test-tube sort of way. But I see no purpose for it if you are designing circuits that result in a functioning circuit board. Why? Well for starters here's how I see product/circuit boarded designs being approached.
A description of a problem is put forth.
The power source is selected.
The shape factor is decided on.
A block diagram is created.
The implementer's skill set is considered.
The major components are selected.
The supporting components are chosen.
The technology is determined. (SMT or Thru-Hole or ?)
The passives are selected for each subsystem. AIN, AOUT, COMM, PS, DI, DO and the individual sections are designed.
Parts are ordered.
The packaging is selected.
The board dimensions are settled.
The schematic is completed.
The schematic is peer reviewed.
The layout commences. With careful attention to 'crosstalk' and coupling of all types.
Board goes out for fab.
Software development can commence.
The board is assembled.
Bench testing starts.
Any problems are fixed.
Software is completed.
Packaging is mated.
External wiring is completed.
Schematic is rev'd.
Board layout is rev'd.
Unit goes out for some RW testing.
Now I ask you where did I need any simulation? Most modern designs are compartmentalized. Do you need a computer to show you how to drive your output transistors or to do a level shift?
Do you need a simulation to show you how to hook two IC's together?
Or do you need a simulation to design a linear supply?
Ridiculous! A simulator will get you into more trouble! A simulator will distract your mind from getting the job done! Just as soon as you start trying to "understand why your circuit doesn't work like the simulator thought it would you are wasting someones money!! Now you are spending your time trying to puzzle out your tool not your design.
I would guess that designing that switching power supply might be a 'valid' job for a simulator... But it isn't! Why? because the complex IC that is the heart of it isn't model-able to the user. Even if it was, the interaction of the different components as they are laid out on the board cannot be modeled and makes ALL the difference in the functioning of the supply. No, you must refer carefully to the data sheet and its discussion of trace routing and component placement to end up with a functional circuit, so why try to simulate it? Pointless.
Basically if your circuit is complex enough in one huge pile that it could benefit from simulation it is probably too complex to simulate because of all the parasitical interaction that will also then be present.
Most circuits are now comprised of IC's which are not readily simulatable.
Most of a good design includes stuff that isn't even electrical.
Good design results from a clear global picture of the entire design not a myopic focus on a simulated sub-circuit.
Simulation? No thank you, I have work to do.
Keith Cress
Flamin Systems, Inc.-
