CarbonWerkes
New member
Hello-
Im converting an MCU<->MCU interface from I2C to SPI. Problem is, the MCUs are on different PCBs- where one is on a daughter card connected via standard IDC Header/socket. The trace length is minimal- 6" or so. But, I have no experience with routing high-speed signal lines; the I2C version works well (electrically, anyway), but that is at 100khz clock.
Aside from the standard guidlines on EMF/ground planes, can anyone provide me any guidance on dos and donts regarding this type of signal path? That is, are vias OK? Will an IDC header/socket support SPI signaling without horrible reflections, etc? Since this header is effectively the same as is used in a PC IDE motherboard, and since an IDE interface is running with a clock of at least 8Mhz, Im hoping SPI is not a big deal in terms of routing.
Any guidance is appreciated-
R
R
