Spherical Tolerance Zone
CheckerHater
2,889
I recently run into question that I thought could be interesting for the rest of this forum: what spherical tolerance zone is good for?
ASME Y14.5-2009 Fig. 7-35 shows obvious application for locating spherical feature of size.
Now, if I want to locate point in space, there is nothing wrong about that point being contained within spherical tolerance zone.
One possible use is shown on the enclosed picture; all opinions are welcome.
CH,
Yes, we should be able to derive the virtual sharp of a cone. We just need to explicitly specify the method used for the derivation. For a sphere, the maximum inscribed/circumscribed inverse sphere works well but for a cone there is no obvious equivalent. The main question relates to the included angle of the inverse feature - is this angle held constant, or is some sort of fitting algorithm used? In your drawing, the diameter of the cone is dimensioned with a plus/minus tolerance and there is no basic angle.
Evan Janeshewski
Axymetrix Quality Engineering Inc.
I support Evan on this one. I have no problem with the concept of tolerancing a point, but the simulation (AME) is a challenge. Is the AME the cone, or the point? Picture a cone whose apex is for some reason truncated slightly, but still forms a "point"; is that non-apex the point in question, or is it the apex of the conical taper? That, to me, would have to be defined on the drawing.
Jim Sykes, P.Eng, GDTP-S
Profile Services TecEase, Inc.
So, in order for “extension of principle” to work we have to accompany our tolerancing scheme with some sort of a note.
Something like “DERIVED VIRTUAL SHARP”?
