aidangoggin
Can anyone help me with the definition of a Spectrum within CAE, its in relation to a response spectrum analysis to recreate the base excitation of a component.
No one in my University has ever tackled this and they won't pay for support.
I'm trying to recreate a 1G test at 3.5mm from 20-200Hz.
From the Manual it says a spectrum should be defined with in the keyword editor as follows, does anyone have an example of any input so I could get an idea from it:
"Date lines to define a spectrum:
First line:
1. Magnitude of the spectrum.
2. Frequency, in cycles per time, at which this magnitude is used.
3. Associated damping, given as ratio of critical damping.
Repeat this data line as often as necessary to define the spectrum at all frequencies at each damping value."
I really need help with this please and any assistance would greatly be appreciated, thanks
First line:
