rockman7892
- Apr 7, 2008
- 1,176
I know that when you spec a motor its output torque curve has to be greater than the torque curve of the driven load. The best way to do this is the look at both the speed vs. torque curves for the motor and load, and make sure that the motor curve is above that of the load for all speeds.
When specifying the torque rating of a VFD what steps should be taken to verify that the torque output of the VFD will be able to drive both the motor and load? Is there a torque curve for VFD's that can be compared to the motor and load curves as mentioned above?
The reason I ask, is because someone told me that a particular VFD was oversized to drive a particular motor and load. I am now looking to replace this VFD with another model and wanted to see how to correctly size it.
