I don't have the relevant ASME/ANSI standard to hand and Genium DRM doesn't seem to have it.
If you have an area where you want deliberately rough surface finish (in my case to scatter light) is there a 'standard' way of saying it.
I have a drawing from a Designer in which .2" at the end of a bore needs to be 'rough'.
The area is indicated and has a callout saying APPROX .005 ROUGH LATHE MARKS IN HATCHED AREA INSIDE PART.
Until I spoke to the designer I didn't understand what she wanted although now it's fairly clear, also it contravenes para 1.4 of ASME Y-14.5M.
I don't think calling up a knurl is correct.
Is something like "SURFACE FINISH OF AREA INDICATED TO BE 4000 TO 6000 RMS PER ANSI B46.1" more correct?
I need to give a response by about 9am tomorrow Pacific time, any help appreciated.
KENAT, probably the least qualified checker you'll ever meet...
