specification sheet cannot open?
junping
I am pretty sure the spec sheet has been created. There is form no. But when I try to open it, I got "cannot load page #1". What could be the problems?
Under FILE/Preferences/Instrument Specifications/General, the Global Path is not defined. I don't know if that could be the problem. I am not the administrator.
Resolution(s):
Several options for resolutions are possible:
1. Look for the PSR path in the preferences (pulldown menu "File" -> preference -> instrument specifications -> general))
2. Look if there's the Directory c:\temp exists and/or permissions to write exists, or if temporary folder is set at the preferences.
3.If nothing works; create a new login name, this will solve your problem.
Cheers!
Carlo
INtools-Infomaker-CAD
Carlo
CS Webservice-Online
Or try to regenerate the specsheets, that also sometimes helps
