I need to calculate the specific volume of nitrogen (in m3 / kg) of Nitrogen at different conditions of Pressure and temperature ( eg 424.7 kPa and 183 K). Thermodynamics is not my strongest area, but I have tried to calculate values as follows:
Using gas law, From V = n R T /P :
n = amount of substance of gas.
If amount = 1kg, then n = number of moles in 1kg of nitrogen . Molecular weight of N2 = 28.0134 g/MOL, therefore in 1g, n = 1000/28.0134 = 35.69720205 moles
R = gas constant. = 8.314472m3 Pa K-1MOL-1
T = 183.7074046 K
P = 424710 Pa
Now, v = 35.69720205 x 8.314472 x 183.7074046 / 424710 = 0.128381672 m3/kg
However, I am not sure if this is correct ( for example, should I be using a value of R which is specific to Nitrogen ? )
Any guidance much appreciated.
T = 183.7074046 K
P = 424710 Pa
